Hello
Guest
it is
November 01, 2026, 10:06:04 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Posting G Code from Lazy Cam
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Posting G Code from Lazy Cam (Read 11747 times)
orbdm
5
on:
December 28, 2008, 04:19:37 PM »
I am new to the forum and the reason I joined was to get help with a Lazy Cam posting problem I have. I recently purchased a CNC Engraver from a shyster E Bayer. The engraver came with Mach3 CNC and Lazy Cam. I've never done CNC but being somewhat technical I thought I could pick it up enough to at least engrave some plastic placards. My problem is that I imported a simple Autocad.dxf file of a rectangle and used Lazy Cam to add four letters of text. I then posted the file to Mach 3. The engraver starts engraving beautifully then just stops part way into the third letter. When I examined the G code I noticed not all of the code posted. I tried this numerous times with the same result each time. Everything seems to be in place in Lazy Cam but the posting truncates the file. I just read a forum response that implied that the version of Lazy Cam I have may be a trial version and the posting is stopping at 50 lines. Is this my problem? Thanks for any feedback.
Mike
Logged
Re: Posting G Code from Lazy Cam
Reply #1 on:
December 28, 2008, 06:38:06 PM »
Mike,
Start Mach3 and then HELP> About Mach 3 CNC Controler .....and what does it say in the box?
I may be wrong, but thought an unregistered version of Mach is limited to more than 50 lines or so of code.
If it's a trial version definitely can be your problem.
Logged
orbdm
5
Reply #2 on:
December 28, 2008, 08:25:44 PM »
Rich,
You were right on. Mach3 is accepting exactly 50 lines of code. Just checked my versions of Mach3 and Lazy Cam. Mach 3 is running a demo version, Version R2.63. Lazy Cam does not state that it is a demo version. It is version 2.61. Guess I need to order some software.
Thanks for your help.
Mike
Logged
Reply #3 on:
December 28, 2008, 11:03:38 PM »
MACH woud be a good choice, you won't be sorry, get a LOT for the money, that's my opinion. It will be the foundation for other software should you desire something specific but take your time on that stuff.
Logged
orbdm
5
Reply #4 on:
December 29, 2008, 07:25:13 AM »
Thanks Rich. I'll purchase this morning.
Mike
Logged
Print
Pages:
1
Go Up
« previous
next »
