Hello Guest it is October 21, 2026, 12:54:44 AM
Author Topic: You know it's Monday when...  (Read 16756 times)
Offline vlmarshall
  •  23 23
  • G28 G91 X0 Y0
« on: December 25, 2008, 09:49:43 PM »
A drill chuck somehow manages to work it's way off the taper, remaining in the hole it's just drilled, and waits patiently for the next tool to slam into it.
Ah, well.
The drill chuck was fine, other than a few dings, all I lost was one end of a carbide centerdrill.
Haas VF-3, at work.
Re: You know it's Monday when...
« Reply #1 on: December 26, 2008, 06:03:11 AM »
Wow, lucky you had a small soft part there. And you hit it in the best direction. :o
Could have been a lot worse.
Wish you good luck NEXT Mon.  >:D
RC 8)
« Reply #2 on: December 26, 2008, 03:33:01 PM »
 ???  So, why did the center drill come after the drill ?.
Tool changers are great, but you still have to keep an eye out.
Ed
Ed VanEss
Offline vlmarshall
  •  23 23
  • G28 G91 X0 Y0
« Reply #3 on: December 26, 2008, 03:58:55 PM »
RC 8)
Too true, and thanks!  ;D
The center hole in this setup is just a rough clearance hole, drilled with a G81 and no centerdrill, it gets sized and counterbored from the other side in the next setup.
The centerdrill cycle is for a set of 8 holes around the center hole, drilled and tapped for 4-40 threaded inserts.
All of the interesting work goes on once it's flipped over and dropped into the other vise.
Tool changersCNC machines are great, but you still have to keep an eye out.
;D
I love my job. Almost 15 years, and something new every day.
