Hello Guest it is October 24, 2026, 09:47:12 AM
Author Topic: MPG Support, IndexPulse Homing and more  (Read 27344 times)
« on: December 24, 2008, 02:00:47 PM »
Updated the web page with latest software for DSPMC that will support MPG and Homing with Index pulse and/or home sensor.  Don't forget to checkout the PID Graph tool to see response of your drive in real time.
The new MPG update allows encoder hooked up directly to DSPMC, providing real-time MPG response. No more buffered motion.
http://www.vitalsystem.com/web/motion/dspmc.php#Mach3
regards,
VITAL DSPMC Team
Re: MPG Support, IndexPulse Homing and more
« Reply #1 on: March 27, 2009, 03:52:55 AM »
DSPMC Software New Release
Rev 1.92 3/26/09   Requires Firmware 59 or higher
*   Fixed MPG Bugs. scale MPG dial using Ports and Pins -> Encoder/MPG's -> Counts/Unit and the StepsPer inch/mm in motor tuning window
*   added HomingIgnoreLimitSw config in xml to ignore/Not Ignore limits during homing. allows using limit swtches as home sensors
     see example in dspmc.xml
*   added 5sec delay for checking limit sw after homing complete
*   Backlash Comp Redesigned and much improved to avoid oscillation.  Use Dual Loop PID control with simulated load position
*   Feedhold Ramp Up/Dn time now 350msec
*   New user-friendly AxisWorks Interface, with tunning Graph on the main window.
*   Misc bug fixes
best regards,
VITAL DSPMC Team
www.vitalsystem.com/dspmc
« Last Edit: March 27, 2009, 10:44:51 AM by vitalsystem »
« Reply #2 on: March 27, 2009, 07:02:01 AM »
Really cool.
Looks like I will have to upgade the firmware and install the new plugin once I finish this bunch of parts.
Mike
