Hello Guest it is November 13, 2026, 09:54:03 AM
Author Topic: servo won't engage  (Read 48318 times)
Re: servo won't engage
« Reply #20 on: December 31, 2008, 09:48:14 AM »
controller's power suply
the controller is in a case factory made (hopfuly ) and it did run for 6 months so it sould be no problem there
« Reply #21 on: December 31, 2008, 02:44:07 PM »
Is that the same 5V supply that feeds your switch?
« Reply #22 on: December 31, 2008, 05:30:07 PM »
yes it is the same 5 v
« Reply #23 on: December 31, 2008, 05:50:46 PM »
If you put a voltmeter across the 5V supply and its 0V (when PP cable connected to the computer) and press the switch does the voltage drop away?
« Reply #24 on: January 02, 2009, 05:15:03 AM »
it does not hapend any thing
the voltage stays to 5 v
« Reply #25 on: January 02, 2009, 05:18:58 AM »
Well afraid I have no idea, it certainly seems like when you have the PP connected it is not allowing your 5v signal to the fault line of the Gecko but as you have said you dont have the fault line connected to the computer then I am at a loss how this could be.
« Reply #26 on: January 03, 2009, 12:05:33 AM »
when i power up the controller i have 5 v on step and dir term of the geckos is this normaj ?(pp not conected)
or it may be some return voltage
