Hello Guest it is November 13, 2026, 12:28:19 PM
Author Topic: Code hangs and z drils to China  (Read 28323 times)
Re: Code hangs and z drils to China
« Reply #10 on: December 21, 2008, 03:04:56 PM »
Oh meant to add that you seem to have the Z Axis homing in the negative direction, unless your machine has some special kind of setup then that should be reversed to Home positive.
vmax549
« Reply #11 on: December 21, 2008, 03:38:06 PM »
IN Your file that line 4910 is acutally line 491 that is where mach will stop if the license file is not active for some reason. Might want to double check . You will also see an error around line 6810 where there is an error with radius end point not same as starting point on the next line(;-).
Just a thought, (;-) TP
« Reply #12 on: December 21, 2008, 03:44:56 PM »
Chip
 Think you need must have your IJ mode as Abs
« Reply #13 on: December 21, 2008, 07:22:42 PM »
We used the xml files off the dyna setup disc. Sorry, but were a little confused and new to this. Are these settings in mach or sheetcam? Is g4 set in sheetcam or mach 3? Thanks for the help.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #14 on: December 21, 2008, 11:36:58 PM »
Hi, Citade
The G4 setting is in Mach3 Config, General Configuration, See Pic below.
Thanks, Chip
