Hello
Guest
it is
November 23, 2026, 05:10:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Code hangs and z drils to China
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Code hangs and z drils to China (Read 28403 times)
Carnoustie, Scotland
Re: Code hangs and z drils to China
Reply #10 on:
December 21, 2008, 03:04:56 PM »
Oh meant to add that you seem to have the Z Axis homing in the negative direction, unless your machine has some special kind of setup then that should be reversed to Home positive.
Logged
vmax549
Reply #11 on:
December 21, 2008, 03:38:06 PM »
IN Your file that line 4910 is acutally line 491 that is where mach will stop if the license file is not active for some reason. Might want to double check . You will also see an error around line 6810 where there is an error with radius end point not same as starting point on the next line(;-).
Just a thought, (;-) TP
Logged
Reply #12 on:
December 21, 2008, 03:44:56 PM »
Chip
Think you need must have your IJ mode as Abs
Logged
citadelcomputer
7
Reply #13 on:
December 21, 2008, 07:22:42 PM »
We used the xml files off the dyna setup disc. Sorry, but were a little confused and new to this. Are these settings in mach or sheetcam? Is g4 set in sheetcam or mach 3? Thanks for the help.
Logged
Chip
2,055
Gainesville Florida USA
Reply #14 on:
December 21, 2008, 11:36:58 PM »
Hi, Citade
The G4 setting is in Mach3 Config, General Configuration, See Pic below.
Thanks, Chip
Logged
Print
Pages:
1
2
Go Up
« previous
next »
