Hello Guest it is November 13, 2026, 08:06:34 PM
Author Topic: MaxNC 10 on Waveform - No Y-axis movement  (Read 46437 times)
Re: MaxNC 10 on Waveform - No Y-axis movement
« Reply #10 on: December 18, 2008, 12:15:38 PM »
Hi All,
Just tested the pins - and it follows Chips layout -  axis pin's 2,3,4,5,  axis pin's 6,7,8,9,  axis pin's 1,14,16,17
This confirms my theory that its a software related problem, since the machine works in maxnc perfectly, I have x,z control in Mach. I've swapped motors on Y with a known good one and it still doesn't work. And finally the pins match what Chip was saying was the correct layout.
I've also tried a second PC running the same version of software.
Running the latest demo version.
This is interesting.
David
« Last Edit: December 18, 2008, 02:18:55 PM by David Bartlett »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: December 18, 2008, 02:54:07 PM »
Hi, David
I've checked 2 versions of Mach3 hear for outputs both seem to have outputs ver 3.042 being one of them.
A friend has one of these mills, I'll see about checking this out.
Chip
« Reply #12 on: December 19, 2008, 01:13:44 AM »
I also tried an older version mach 3  something like version 1.83
« Reply #13 on: May 06, 2009, 10:58:37 PM »
Still looking for the Y-axis. Any new suggestions?
Thanks.
« Reply #14 on: May 07, 2009, 03:33:24 PM »
Dave,
Try this xml for your mill and see if it works. I had my maxnc running with this configuration. You may have to make a few adjustments in the motor tuning, etc. to suit your mill.
Jeff
« Last Edit: May 07, 2009, 03:36:13 PM by blackrat6355 »
« Reply #15 on: May 07, 2009, 09:04:56 PM »
Progress.
Jeff, that got all three steppers buzzing! Now I just need movement. Any suggestions? Prio I could never get the y-axis to buzz, but the other two moved.
« Reply #16 on: May 07, 2009, 09:08:04 PM »
Ah you have CL mode selected vs. wave drive.
« Reply #17 on: May 08, 2009, 01:59:19 PM »
Hi Dave,
Was just wondering if you've had any luck with getting your axis's to jog. There are lots of documention on the MaxNC 10 here in the forum, just do a search for it.
Jeff
« Reply #18 on: May 08, 2009, 07:38:27 PM »
Not yet. I've been able to get them to buzz (spin) in all directions under CL mode. Changing motor settings, I can adjust the frequency of the buzz..
And again under waveform mode I have two directions, but no third.
David
« Reply #19 on: May 09, 2009, 06:09:52 AM »
Hi Dave,
Check out this posting in the forum and see if it helps you any.
http://www.machsupport.com/forum/index.php/topic,1319.0.html
I'll keep searching and see what I can come up with to help.
Jeff
