Hello Guest it is November 24, 2026, 03:06:09 AM
Author Topic: G13 Circular pocket and cutter comp??  (Read 12490 times)
Offline Roy
  •  16 16
« on: December 12, 2008, 04:34:59 PM »
Is there a way of getting Mach 3 to understand cutter comp in a G13 circular pocket move?
If I run the code as follows for a 20mm diameter pocket and using say a 10mm cutter, mach ignores the D offset and thus produces a 30mm pocket!
G13 I10. D3 F200
This is how I would usually programme the circular pocket on my Haas (which obviously understands cutter comp completely!)
So does anybody know a way of utilising cutter comp in a G13 pocket cycle, or do I have to allow for it in my programme? ( Which is a pain in the A@@e when doing limited pockets!)
Thanks, Roy
1986 Denford Triac Mill running on Mach 3 Via CNC4PC breakout board.
Offline vlmarshall
  •  23 23
  • G28 G91 X0 Y0
Re: G13 Circular pocket and cutter comp??
« Reply #1 on: December 15, 2008, 12:42:13 AM »
Ah, I was wondering about this one as well. Not just the cutter comp, but the rest of a G13 canned cycle; G13 I6. K10. Q2. F200., to follow your example. Tool stepover and a finish cut are often quite useful.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: December 15, 2008, 10:42:31 AM »
Cutter comp is getting a work over right now so things should be much better very soon.
Graham
