Hello Guest it is November 13, 2026, 10:01:01 AM
Author Topic: Control Hardinge spindle speed?  (Read 13553 times)
« on: December 12, 2008, 03:15:58 PM »
No, not using a VFD, that would be too easy...  ;D Has anyone used Mach to control their Hardinge (well, I have a Feeler FSM-59, a Hardinge DV-59 clone) mechanical VSD in Mach?
I have a QRB1134 retrosensor pointed at the spindle handwheel, one half of which I painted white to give 1 pulse per revolution.  The sensor is feeding a Tachulator digital tach, but I can pull off the 1 PPR signal to feed back to the PC.
Controlling the VSD would involve acutating "higher" or "lower" solid-state relays to run the speed change motor forwards or backwards until the spindle pulse was at the correct frequency.  I'm a stepper-using guy myself, so I have no idea how this would be implemented in the software.
Just a "wonder if" idea for now... My lathe is a 3-phase, and I have a TECO FM-50 VFD generating the 60Hz 3-phase from 208V 1-phase input.  If I were to install a VFD-rated spindle motor ($$$) I'd need to also replace the coolant pump (more $)
Randy
Re: Control Hardinge spindle speed?
« Reply #1 on: December 12, 2008, 05:01:50 PM »
I dont think it would work out very well, I think there would be too much delay with relays and motors and feedback to be able to settle at a speed.
 Maybe fitting a stepper instead of the speed change motor would work. You could set it up as an axis and have your spindle speed macro send it so many steps for a given speed.
« Reply #2 on: December 13, 2008, 02:24:12 PM »
Thanks for the reply, Hood.  I will leave the setup as is.  I'm not sure that a stepper axis would work, becasue there seems to be hysteresis in the speed-control system due to the way it operates (split-pulley) and changing up to a given speed and changing down to the same speed would probably have different positions.
Best regards,
Randy
« Last Edit: December 13, 2008, 02:32:46 PM by zephyr9900 »
