Hello Guest it is October 21, 2026, 12:55:12 AM
Author Topic: V2.82 ready for test, also for Tormach users  (Read 149005 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: V2.82 ready for test, also for Tormach users
« Reply #10 on: December 10, 2008, 09:03:40 AM »
Can the unneeded Tool Comp Moves be done away with?Below is a program that does 2 Cut Rectangles that uses same tool.I have edited it to remove the unneeded Comp moves and other editing.
(Code by Newfangled Wizard, 12/10/2008)
(Program Posted for Aluminum )
G0 G49 G40.1 G17
G80 G50 G90 G98
G20 (Inch)
(***** Cut Rectangle *****)
M6 T1
M03 S4000
M8 (Flood On)
(Inner rectangle)
(conventional mill)
G00 X0.375 Y0.1875 F15
Z.1
G42 P0.127
G01 X0.5625 Y0.1875 F50
G02 X0.75 Y0 R0.1875
G01 Z-0.18 F50
G01 X0.75 Y0 F7.5
G01 X0.75 Y0
G02 X0.61 Y-0.14 R0.14
G01 X-0.61 Y-0.14
G02 X-0.75 Y0 R0.14
G01 X-0.75 Y0
G02 X-0.61 Y0.14 R0.14
G01 X0.61 Y0.14
G02 X0.75 Y0 R0.14
G01 X0.75 Y0
G0 Z0.1
(Inner rectangle)
(conventional mill)
G0 X0.75 Y-0.722
G01 Z-0.18 F50
G01 X0.75 Y-0.722 F7.5
G02 X0.61 Y-0.862 R0.14
G01 X-0.61 Y-0.862
G02 X-0.75 Y-0.722 R0.14
G01 X-0.75 Y-0.722
G02 X-0.61 Y-0.582 R0.14
G01 X0.61 Y-0.582
G02 X0.75 Y-0.722 R0.14
G01 X0.75 Y-0.722
G0 Z0.1
G02 X0.5625 Y-0.9095 R0.1875
G40
G0 X0.375 Y-0.9095
M5 M9
G28
M30
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
« Reply #11 on: December 12, 2008, 08:38:05 PM »
Can't get license to work. I don't have e-mail on my machine computer so I copied to a thumb drive and put it in the newfangled file.
What did I do wrong? It's a .dat file. It's a new Tormach machine.
Rory D.
Rory D.
"If I didn't live in the middle of nowhere!"
« Reply #12 on: December 13, 2008, 07:07:58 AM »
The license should be in the base folder, not in the addons or newfangled folder. Im the standard version it shold be C:\Mach\WizLic.dat. I think Tormach uses C:\PCNC\WizLic.dat
« Reply #13 on: December 13, 2008, 10:34:24 AM »
I just tried that, still I get message "Unlicensed wizard file". I have the worst luck with downloads.
Rory D.
Rory D.
« Reply #14 on: December 13, 2008, 11:11:06 AM »
Art wrote the code that tests the license, I have no idea how it works. Its possible he has a hard coded path, try putting the license at C:\Mach3\WizLic.dat Only other suggestion I have is to request a new license file from the Newfangled site. Send a mail explaning whats happening, Scott will replace your license.
« Reply #15 on: December 13, 2008, 11:08:14 PM »
Really was no issue just me not knowing I needed to load th elicense key for Mach3 first.
Rory D.
Rory D.
« Reply #16 on: December 14, 2008, 06:41:57 AM »
Unfortunately the zip file I downloaded gives a failure when I try to extract it (several times zip file corrupted)
I repaired it using the repair option of winzip and it worked but still with CRC error announcements.
Can I use this safely on my computer not destroying my 2,79 set?
kind regards,
Andre
« Reply #17 on: December 28, 2008, 03:13:37 PM »
Ron....I am a Tormach user with the latest software and get an error when I try to pull the tool info from the table.  It does not recognize the "get tool desc" on line 30.
You may remember me, I am the guy who worked with you on the ability to pull the information from the tool table many months ago.
Any idea what's happening?
Pat
« Reply #18 on: December 28, 2008, 03:33:41 PM »
Tormach does not have the getToolDesc command in its version. In the most recent version of the wizards I have code that looks to see if the path is not C:\Mach3. It not it is supposed to skip the gettooldesc command and just insert the word 'unknown'
Are you using 2.82 and this is not working?
« Reply #19 on: December 28, 2008, 06:30:58 PM »
Ron,
I am using the latest zipped version file I could find called "Newfangled282.zip"
Here is the code I have been using that I added to your screen in a prior version (v2.77) to pull up the tool diameters and descriptions.  It works perfectly.  You may be correct that ToolDesc doesn't work so I use a DRO that pulls up the Tool Description bases on the tool number like Tormach does in their screens. (check out the program line...."SetOemDRO(824,ToolNumber (Dlg1.listbox))    'set minimized Tool#DRO so that TOOLDESC DRO will Update")
Sub main
' read tool info from tool table and update DROs for tool number and dia
Dim ToolNumber (256) As Single
'''''Dim ToolDesc (20) as string
Dim ToolDia (256) As Double
Dim ToolDisplay(256) As String
CurrentTool = 1
ToolCnt=0
For CurrentTool=1 To 255
  ''''''ToolDesc (CurrentTool) =
  TempDia = GetToolParam(CurrentTool , 1)
If TempDia>0 Then
  ToolNumber (ToolCnt) = CurrentTool
  ToolDia (ToolCnt)= TempDia
  ToolDisplay(ToolCnt) = Format(ToolNumber (ToolCnt),"000")  & "  ("  & Format(ToolDia (ToolCnt),"0.0000") &""")"
  ToolCnt=ToolCnt+1
 End If
Next CurrentTool
Begin Dialog ToolBox 256,89, "Select Tool from Tool Table"
  OKButton 204,24,40,14
  CancelButton 204,44,40,14
  ListBox 50,24,128,60, ToolDisplay (),  .listbox
  Text 50,17,128,10,"Tool # (Tool Dia) "
End Dialog
Dim Dlg1 As ToolBox
Button = Dialog (Dlg1)
If Button=0 Then  'cancel button
  Exit Sub
End If
SetUserDRO(1007, ToolNumber (Dlg1.listbox))
'''''''SetUserLabel (1,ToolDesc(count))
SetUserDRO(1004, ToolDia (Dlg1.listbox))
End Sub
main
