Hello Guest it is November 22, 2026, 06:52:59 AM
Author Topic: New version of probing plugin  (Read 10384 times)
« on: December 09, 2008, 11:19:34 AM »
Hello Everybody
I have downloaded new version of probing plugin from artofcnc.ca. I use tool for finding center of the hole only. I used some previous version of this, without any problem. I had to reinstall mach3, because of change of my computer.
But new version does not work. Probe touches 4 points inside the circle. Last one is in -Y direction. Then it should go to the center of the hole, but it continues in -Y direction. If I would use it seriously, not just for test, my probe would be broken.
Do you have any idea? Or do you have some older version of this plugin?
Thanks for any help
Aluman
