Hello
Guest
it is
November 01, 2026, 10:06:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Cutter comp Issue
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cutter comp Issue (Read 11299 times)
Psad
82
Cutter comp Issue
on:
July 10, 2006, 12:01:37 PM »
Attached are two files (dxf and tap). During run progam i get an error on line N70. It looks like the cutter is getting too close to the next edge. error says "Tool radius no less than arc radius with comp on line numbe(message get cut off). Have a look.
Lots of progress on the last update. Good work
Logged
Brian Barker
3,860
Re: Cutter comp Issue
Reply #1 on:
July 10, 2006, 12:15:46 PM »
This is the limitation of cutter comp
I am working on offseting the path in Lcam to help with this probelm
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ger21
6,295
Reply #2 on:
July 13, 2006, 11:03:34 AM »
Any radius on an inside corner must be at least the tool diameter or larger. The tool can't follow the path if the radius is smaller than the tool You can turn off advanced comp, but you'll get gouging in the corners then.
Logged
Print
Pages:
1
Go Up
« previous
next »
