Hello Guest it is October 21, 2026, 12:51:08 PM
Author Topic: Homing gantry with smooth stepper  (Read 32242 times)
Re: Homing gantry with smooth stepper
« Reply #10 on: August 22, 2009, 07:29:09 AM »
Hood:
Do you use the C23 BOB.
« Reply #11 on: August 22, 2009, 07:42:06 AM »
No.
« Reply #12 on: August 22, 2009, 07:44:21 AM »
What BOB's are good with the SS?
« Reply #13 on: August 22, 2009, 07:53:38 AM »
I only use PMDX 122, they have worked well for me without any issues so no need to change. I also use a CNC Building Blocks BOB on the lathe and Beaver Mill in conjunction with the PMDX but the reason was I was wanting Index homing which these boards did. I no longer use that feature as my servo drives can do that internally so if I was doing it again I would just have 2 PMDX 122's.CNC Building  Blocks is no longer making stuff anyway so they are no longer an option.
« Reply #14 on: August 19, 2012, 04:43:14 PM »
I'm seeing something with my set-up that looks suspiciously like this thread, but it's with a new ethernet SS.  I was wondering if a solution was ever found?
My setup is a CRP-4848, ESS (V0), PMDX-126.  Homing acts very oddly if I enable the A-Home switch in Mach3.  Sometimes the X-axis will continue to move back and hit the physical stop or the A-axis will move forward after the X-axis moves off the X-home switch.  I do not have homing slaved in the General Settings.
Home works if I disable the A-Home in the Ports & Configs, but it won't square the gantry.
-Freeman
I'm not a complete idiot...
    there are some parts missing.
Offline sebba
  •  42 42
« Reply #15 on: August 28, 2013, 03:14:13 PM »
Hello,
I just installed a new ESS and the homing procedure have simillar issues.
Does anybody know how to fix the homing with slave axis?
Homing for X, which is a single driven axis work well but homing Z (and B, which is slave for Z)  or Y (and C, which is slave for Y) does not.
Issues are very simillar with the issues already described in this topic.
Seb
