Hello Guest it is November 25, 2026, 11:13:06 PM
Author Topic: Brian Barker: Can you make JCode 6 axis... P L E A S E  (Read 30074 times)
Re: Brian Barker: Can you make JCode 6 axis... P L E A S E
« Reply #10 on: December 29, 2008, 09:44:24 AM »
Pardon my ignorance...but...
What is a Ping Pong Machine??
Kudos on the script!
Regards
Fernando
« Reply #11 on: December 29, 2008, 09:54:07 AM »
It's a ball machine that 'pitches' balls to you so that you can practice your strokes.
I'm adding automation/programing to one that already exists http://www.newgy.com/Products/RoboPong540.asp
I will be able to change/control spin, speed, placement, and machine position behind the table.
I should be done with it any year now.
Offline v tec
  •  31 31
« Reply #12 on: November 18, 2012, 03:47:49 PM »
hi, i m interesting by your plugin, for use on my arm robot 6 axis
but i understant nothing at your code, i have never write a code...
