Hello Guest it is November 22, 2026, 08:00:50 AM
Author Topic: re wrong direction at tool change  (Read 12502 times)
« on: December 06, 2008, 01:54:35 PM »
can some one look at this gcode particularly at the tool change on tool #3 it goes g 53 zo and then it goes z.1 witch is clearence height of part but in stead of goingdown to the tool clearance height mach goes up and hitsthe limit remembering you are sitting just of the home switch when it does this.The machine has bee homed and all tool offsets set up and g code loaded and everything set up correctly i can not figure this one out .Thank In advance.
« Last Edit: December 06, 2008, 03:21:14 PM by woffler »
Re: re wrong direction at tool change
« Reply #1 on: December 06, 2008, 02:10:50 PM »
I think for anyone to test properly you will also have to attach your tools.dat file and your xml. As usual with the forum if a file has already been uploaded you will have to change its name.
« Reply #2 on: December 06, 2008, 03:22:28 PM »
hood i think i got what you wanted in the zip folder here if not let me know and il try again thanks
