Hello
Guest
it is
October 20, 2026, 03:07:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mapping output #6 to another pin?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mapping output #6 to another pin? (Read 11913 times)
ecm
3
on:
December 05, 2008, 09:10:31 AM »
A newbie question ... I have the X & Y running fine. But I'm trying to get my Z axis control circuit working in a "2.5" configuration. Given my stepper output board layout, it would be a lot easier if I could map the 2.5D output, normally set up "6" to another pin. Say 15. Is there a way to do this in Mach 3? Or am I locked into pin 6 for the Z axis control? Thx ...
Logged
HimyKabibble
1,687
Re: Mapping output #6 to another pin?
Reply #1 on:
December 05, 2008, 11:01:01 AM »
You can map any signal to any pin. Just go to Config->Ports & Pins.
Logged
jimpinder
1,232
Wakefield, West Yorks, UK
Reply #2 on:
December 05, 2008, 12:08:20 PM »
If you are using the LPT1 port, then you can't use pin 15 which is an input and cannot be changed to output. The other outputs are 1,14,16 and 17.
If you are using some configurable input/output board, then yes.
Logged
Print
Pages:
1
Go Up
« previous
next »
