Hello Guest it is October 20, 2026, 03:08:10 PM
Author Topic: what am I doing wrong?  (Read 28832 times)
Re: what am I doing wrong?
« Reply #10 on: December 05, 2008, 03:39:15 AM »
Hood wrote:
Might be an idea to delete everything in the Mach folder and re download Mach and install again.
I have done this yesterday as per Your suggestion, first trial was ok as feed DRo but not actual cicle time.
pc where I'am testing now is a laptop 1.8g with 1 g of ram , ( I know I should not use a laptop but this is the pc where I test blank the program and never had problem with rel 1.84) This evening I may try to update a more powerfull desktop to see if it is the pc
Gianluca
« Reply #11 on: December 05, 2008, 03:46:19 AM »
Do you have Machs  parallel  port driver instaled on the laptop?
« Reply #12 on: December 05, 2008, 03:58:31 AM »
Yes, i made a complete installation
Gianluca
« Reply #13 on: December 05, 2008, 04:07:43 AM »
Run the driver test and see what it looks like. You could also try uninstaling the driver from device managr. Laptops are notorious for giving poblems, some work some dont.
« Reply #14 on: December 05, 2008, 06:00:41 AM »
the driver test does not looks good, a message appear 'pulsing too fast'.
this evening will try to install it on a desktop pc
thanks
Gianluca
« Reply #15 on: December 05, 2008, 07:12:56 AM »
If you remove the driver the laptop may well run fine for simulation purpose. If you want to use the laptop to control a machine then you would have to go with an external motion controller such as the smothtepper.
« Reply #16 on: December 06, 2008, 04:15:35 AM »
Many thanks Hood,
I have done what You suggested and now the program runs well on the laptop as simulation and I had no problem loading it in full on a desktop,again simulation as no machine in connected.
I am ready now to do the installation on the machine pc.
thanks
Gianluca
