Hello Guest it is November 23, 2026, 03:14:28 PM
Author Topic: Lazycam Turning Problem  (Read 15252 times)
« on: December 02, 2008, 12:10:49 AM »
Dear All
I have made one Dwg in autocad and opened in lazycam as turning job. i have licenced fir LC and Mach3. The problem is Gcode file generated by LC is not opening in the Mach and showing "Radius to end of arc differs from radius to startLine 29" this error. i am attaching some of the photos with test.tap file. can any body tell me why this is happening.
sanlee
Re: Lazycam Turning Problem
« Reply #1 on: December 02, 2008, 05:44:09 AM »
sanlee,
Try reducing the width of the grooving tool. Also make note what your posting options are out of the program.
Play with the varius settings of the tool to see what happens for your learning.  You need to have a point tool to go around the ball
on the other side as a any tool with width would hit the profile in practical machining. Thus tool change required unless very small turning. Also make sure the sharp corners have a radius which is larger than the tool radius. Also review the material on LaycamTurn located in the members docs section.Post the dxf file .
Later......RICH
oops.... sorry see you posted it ;)
« Last Edit: December 02, 2008, 05:46:33 AM by RICH »
« Reply #2 on: December 02, 2008, 11:26:37 AM »
sanlee,
Can you post the dxf file.
« Reply #3 on: December 02, 2008, 05:52:13 PM »
sanlee,
Your file as seen in MACH v3.041.
« Reply #4 on: December 04, 2008, 01:45:16 AM »
Thank you RICH
When i change the IJ mode from Absolute to Incremental my problem is solved. and i have downloaded MACH V3.041 in this my file seems similar to what you have shown. Also see the attached dxf file as told by you.
thanks again.
sanlee
« Reply #5 on: December 04, 2008, 04:57:50 AM »
Now all you need is to make a point tool to cut it. :)
