Hello Guest it is September 19, 2026, 09:54:10 PM
Author Topic: Another Wizard Suggestion... Drill or Circular Pocket Option  (Read 111750 times)
Pegasus
Brian,
I know your soliciting suggestions so let me throw this one out there:
On the existing wizards that use drilling (Rectangular Hole Pattern and Holes Around A Circle come to mind) how difficult would it be to specify Circular Pockets instead of a straight drilling operation?
This would allow the same wizards to be used with bits that are too small to drill the hole by themselves.
Pegasus
Re: Another Wizard Suggestion... Drill or Circular Pocket Option
« Reply #1 on: July 09, 2006, 12:10:35 PM »
I think this is doable but it is going to take some time ... I am working on LazyCam at this point but hope to have time in a few months or so...
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 29, 2007, 11:35:13 AM »
dear members,
I'm a newby trying out the newfangled wizzards.
All the hole related wizzards doesnot work
on the circular hole pattern the error is error on line 33 type mismatch
on the linear hole pattern the error is error on line 29 type mismatch
on the drill hole position the error is error on line 42 type mismatch
All the other wizzards work!
Any idea what goes wrong??
It you be so kind to answer
Andre
« Reply #3 on: March 29, 2007, 12:02:28 PM »
Can you tell me more about the error? They work OK for me.
What other setting are you using? number of holes, diameter, etc. Also which hole type- peck, drill, did you select?
Which button do you pres to see the error.
ron ginger
« Reply #4 on: March 29, 2007, 12:46:21 PM »
Ron,
I have changed as little as possible
but for instance:
material selction steel hard max spindle rate 4000 max feed rate 100.0 units inch  so default values
then continue
surface speed for special tool 1.0 ft/min tool 4 tooel dia 0.1250 HSS number of cutting tips 4
chip load per tooth 0.0009 inches spindle direction CW Flood Overrides 100% Feed 0% percent plung feed rate 50 spped 764 rpm feed rate 2.8
continue
Z center 5.0000 Y center +0.0000 5 holes Circle diameter +20.000 start angle +0.000 drill G81
rapid height +0.1250 Peck depth -0.2500 Hole depth -1.000
Preview
error showing
Mach3Scripts
error on line :33 -type mismatch
after OK
the erro script opens
after closing
Save changes to HiddenScript.m1s?
No
Then cancel exit and the main screeni sshowin the folowing code:
G0 G49 G40.1 G17 G80 G50 G90
G20 (inch)
M5 M9
M30
Thats all
« Reply #5 on: March 29, 2007, 06:53:23 PM »
It works for me with those same values, but there are a couple strange things. You have feed set to 0%, that shuould generate an error when you try to calculate the feed and speed. It also seems strange that you have a Special Surface Feed of only 1 ft/min.
But none of these should cause you to see a VB error.
If you use the Post Code button does that work?
What version are you using? the Wizard should show its version on the first screen.
ron ginger
« Reply #6 on: March 30, 2007, 11:42:08 AM »
Ron,
if I remove both the Z=0 and Q=0 sentences from the VB script it seems to work.
Can i safely remove them?
Kind regards,
Andre
« Reply #7 on: March 30, 2007, 12:34:47 PM »
Which wizard are you running? The Newfangled Solutions wizards are supposed to be password protected so you cant see the VB code.
Can you cut the VB code and paste it here so I can see the code you are looking at- then I can be sure what wizard we are trying to fix.
ron ginger
« Reply #8 on: April 01, 2007, 04:15:58 AM »
Ron,
I send you the wizzard which is a newfangled wizzard.
Are you able to react already?
kind regards,
Andre
« Reply #9 on: April 01, 2007, 07:45:25 AM »
Sorry, but I have not received any more information on this problem. Can you post the section of the VB code you have trouble with to this forum.
ron ginger
