Hello Guest it is November 19, 2026, 02:48:18 AM
Author Topic: feedrate override  (Read 13626 times)
Offline ataxy
  •  31 31
feedrate override
« on: November 28, 2008, 04:14:19 PM »
do you have to enable fro or should it work automaticly when i click f10-f11 the fro dro changes but the actual feed dro stays the same
Re: feedrate override
« Reply #1 on: November 28, 2008, 04:38:13 PM »
No you shouldnt need to do anything.
What version of Mach? Can you attach some code and the xml you are using and I will see if I can repeat here.
Offline ataxy
  •  31 31
« Reply #2 on: November 28, 2008, 04:49:39 PM »
lockdown that i downloaded yesterday
« Reply #3 on: November 28, 2008, 05:16:00 PM »
Go to config then General Config and at the right hand side you will see you have "No Feedrate on Queue " checked, uncheck it and you shouldbe fine.
 Also are you meaning to have a pink background to your toolpath display, if not go to Config then Toolpath and set the background colours  to zero and that will get you the normal black background.
