Hello Guest it is October 21, 2026, 06:10:30 AM
Author Topic: Do you know what this is? See picture.  (Read 40053 times)
Offline jaja
  •  68 68
« on: November 28, 2008, 07:55:13 AM »
Bought a secondhand lathe (AI hembrug from the Netherlands), a beautifull machine, and a small mill.
With it came a lot of parts, tools and equipment.
After a lot of puzzeling most of the things are clear, so i know how they are used, or what their purpose is.
But three parts are a mystery for me.
So have a look, and perhaps you know a thing or two about it.
First two pictures:
This is some sort of collet, but the three parts are not separated, so it is not possible to clamp something in it.
Re: Do you know what this is? See picture.
« Reply #1 on: November 28, 2008, 09:45:34 AM »
Can you post a pic looking along the side. If the back part is a collet, then you could just mount it in the head of the lathe and use those three slots along with some custom clamps to hold odd shapes or mimic a three jaw chuck.
Do an internet search on jewlers lathes and you'll find all kinds of stuff.
Offline jaja
  •  68 68
« Reply #2 on: November 28, 2008, 10:09:39 AM »
as you can see the inside is still connected with the outside, so you can not force the three parts to the inside and clamp something
Offline jaja
  •  68 68
« Reply #3 on: November 28, 2008, 10:35:10 AM »
Offline jaja
  •  68 68
« Reply #4 on: November 28, 2008, 10:38:34 AM »
i know this is some sort of a chuck, but i've got nothing that fits in it
« Reply #5 on: November 28, 2008, 10:42:39 AM »
It's a blank collet. The face should be soft, thus you can machine the face, like incremental rings which would hold by id or od. You then drill a larger thru so you can draw it up with the bar.
You can make a holding jig out of it or whatever.
« Reply #6 on: November 28, 2008, 10:47:33 AM »
YOUR REPLY #4,
i think that mates to a cam lock type mounting plate and can repelace the chuck . Don't know about the inner boring, check if any other pieces you got a a matching profile .
Offline jaja
  •  68 68
« Reply #7 on: November 28, 2008, 10:53:54 AM »
Rich,
thank you very much for your answer
it clear now
none of my friends knew what it was, so you are a great help
thanks
Offline jaja
  •  68 68
« Reply #8 on: November 28, 2008, 11:01:08 AM »
here is the text for the last three pictures (did something wrong with posting it)
i really don't know what this is
has it got something to do with a lathe or a mill???
is it a mould,,, can you poor a liquid in it to become solid?????????
the white material is like rubber or silicone
i haven't got a clue
« Reply #9 on: November 28, 2008, 11:35:21 AM »
That actually looks like a vacuum table/fixture of some kind.
Is there a tapered threaded hole on the side or bottom for an air fitting?
