Hello Guest it is October 21, 2026, 09:06:52 AM
Author Topic: computer causing gorilla cnc glitch  (Read 27093 times)
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
Re: computer causing gorilla cnc glitch
« Reply #10 on: November 29, 2008, 12:29:08 PM »
I'll also add that I've used my mach 3 controller several times with 3D files that have taken 8-9 hours on a medium sized mill cutting Brass and Aluminium at 300mm/min and Mach has never failed mid file.
Steve
« Reply #11 on: December 01, 2008, 03:22:20 AM »
Gorilla CNC User,
Adding an additional PCI parallel port wont stop the problem you are having.
What is causing the issue is intentionally built in to the BIOS and operating system.
It is not a matter of a defective P.C. or parallel port
First the BIOS on the motherboard polls the port or interrupts
Secondly Windows also polls the ports and interrupts during startup.
The only solution is to add a charge pump and wire it so the motor drivers are disabled when Mach3 is not running.
Jeff...
