Hello Guest it is November 23, 2026, 03:14:31 PM
Author Topic: Jogging with keyboard and MPG?  (Read 12349 times)
« on: November 21, 2008, 11:52:50 PM »
Can I make Mach3 3.042 jog with the keyboard and MPG together? If yes how?  When I select MPG on the (TAB MPG screen) the keyboard doesn't jog.
I wanted to have the keyboard jog at full speed and the MPG slow to get the machine to spot I need,  the X axis is long so when by the keyboard I would jog it to the approx position and then walk over to the moving head that has the MPG on it and get it to the spot I need.
Dennis
Re: Jogging with keyboard and MPG?
« Reply #1 on: November 22, 2008, 04:15:51 AM »
You can only use one or the other as far as I know. What you could do is have a physical button set up on your pendant to change between Jog and Keyboard, that would allow you to change back and forth easily.
« Reply #2 on: November 27, 2008, 02:14:37 PM »
The button is what I will do.
Thank you Hood!
