Hello Guest it is November 22, 2026, 08:36:28 AM
Author Topic: Hot Swap ATC (m6 demo)  (Read 12089 times)
« on: November 21, 2008, 11:44:23 AM »
Here is a Demo of a HotSwap 36 tool ATC.
Screen shot of the ATC Location page.
If you want to demo it on your system.
download the 2 HotSwap Zip files.
Put the Screen Set, and XML in the Mach3 main folder
Put the Bitmaps in the Bit maps folder in the order you see the folders. i.e. C:\Mach3\Bitmaps\folders
It is Demo M6Start.mcc that shows the tools swapping, and the "C" axis rotating to positions, if you watch the ATC Tool location page, you can watch the Tool Slot DROS update.
Due to the size of the bitmaps, this will be posted across several post here.
scott
Re: Hot Swap ATC (m6 demo)
« Reply #1 on: November 21, 2008, 11:48:16 AM »
This one has the first Zip that contains the XML, M6Start.mcc, and the first set of Bitmaps.
« Reply #2 on: November 21, 2008, 11:52:46 AM »
Here is the 2cd Zip file with the remaining bitmaps.
Note:  there is something strange with the ".mcc" system, the standard M6Start.m1s runs no problems, BUT, when it is comiled to a .mcc when it runs there will scroll a "compile error" BUT, it runs anyway...........  ?
Perhaps if others notice this, perhaps those who are seeing other  .mcc errors compared to .m1s, perhaps we can get Brian to look into it.
scott
vmax549
« Reply #3 on: December 04, 2008, 05:06:18 PM »
Scott is there a version of the macro that is NOT compiled(;-)
