Hello Guest it is November 01, 2026, 10:05:45 AM
Author Topic: LazyCAM 2.56 MachManIP MFC Errors  (Read 45765 times)
Re: LazyCAM 2.56 MachManIP MFC Errors
« Reply #10 on: September 02, 2006, 10:32:43 PM »
Hello Chip,
   Here are the files you asked for, (I hope)
..............................Edmund............................
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #11 on: September 03, 2006, 09:29:30 AM »
Hi, Edmund
The Problem is in your DWG file, there were 2 extra lines on top of the left side line from your 0,0 pos. up about .75 inch and 1 inch. I removed them all is fine now.
Hope this Helps, Chip
« Reply #12 on: September 03, 2006, 07:41:09 PM »
Chip,
Here are the 2 files you asked for..
« Reply #13 on: September 15, 2006, 01:47:27 PM »
Chip, can you explain how to delete extra lines in a autocad DXF? dwg that are not visible until I load into LC, I have grey dotted lines all over the place and at least 10 unwanted lines on a rectangle, even when I click on the blue line of the rectangle the blue line does not change to red completely the unwanted lines are interfering
Offline Chip
  •  2,055 2,055
« Reply #14 on: September 15, 2006, 07:11:37 PM »
Hi, Edmund
I loaded the file back into a Cad program and deleted dup. lines there, I think LazyCam's Remove Redundant Button  is for this but is not
implemented at this time.
Hope this Helps,Chip
« Reply #15 on: September 15, 2006, 07:58:13 PM »
I get these errors too, in V2.64 especially when I :
- use the right mouse button and get a funny little pop-up tool that has to do with tool chain selection
- Try to use tool direction arrows
« Reply #16 on: September 15, 2006, 09:38:53 PM »
There is a new version Of Lacm that will take out redundant lines on it's own.... Try it and see if it works for you...
2.65 should help
www.newfangledsolutions.com
www.machsupport.com
« Reply #17 on: September 15, 2006, 10:07:31 PM »
How do I that?,  what is the procedure?, when I go into the drawing in autocad and turn off the holes and slot leaving just the outside rectangle there are lines not showing ie its not a complete rectangle, the drawing has 4 layers, but not sure how to delete the lines, the drawing has lines not joined and yet when I load the drawing into LazyCam it shows a complete rectangle, but there are about 8 little stubby lines all connected by grey dotted lines with extra half curves,
What a mess why cant things work for me, its very ex hastberating
Offline Chip
  •  2,055 2,055
« Reply #18 on: September 16, 2006, 02:48:35 PM »
Hi, Brian
I have looked at fresh download of Mach3. FTP\LazyCam, and LazyCam download, Can't find ver. 2.65 ?
Can you point me to it.
Thank's, Chip
Offline Chip
  •  2,055 2,055
« Reply #19 on: September 16, 2006, 02:58:57 PM »
Hi, Edmund
In your cad program you should be able to Hi lite the line segment that has Dup. items, Delete them, then re-draw the line back in.
Turn on each layer one at a time you may have line segments on the wrong layer, if so delete them then go back to your rectangle layer delete the problem layer then re-draw it.
Post your DXF File
