Hello Guest it is November 20, 2026, 11:55:47 AM
Author Topic: Screen4 has PMS, help me.  (Read 16034 times)
« on: November 21, 2008, 06:58:58 AM »
I am having problems with screen4. It locks up and/or takes minutes to respond when I click on the main menu’s [file, edit, view, defaults, help]. Also some other weird things have happened [most likely user error] like saving a file and reopening it to find everything has shifted over by 800 pixels!
Is anyone else finding these problems? How can I fix it?
Re: Screen4 has PMS, help me.
« Reply #1 on: November 21, 2008, 09:58:23 AM »
That doesn't sound right at all (of course you already know that).
While it's not a "perfect" piece of software, what you're experiencing sounds like a bad install.
Have you tried uninstalling and re-installing?
« Reply #2 on: November 21, 2008, 11:18:08 AM »
Thanks Dave,
I have installed it over 4 times now.
The original screen editor seems to work fine but I cant save as a  “set file”.
When I download screen4 from the mach website, would it make any difference if I turn off the firewall and spy ware on my computer? Can that mess with the file being downloaded?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: November 21, 2008, 12:11:08 PM »
it sounds like you are running it on VIsta...it is not supported for Vista  ::)
Either that or make sure you have targeted the "Mach Location" correctly: Default/Mach Location
« Reply #4 on: November 21, 2008, 01:26:29 PM »
Hmmm.... are you indeed running Vista as mentioned above? If not, what OS are you using?
As for firewall interupting your download, I would think if the file got corrupt during download, it would show immediately while installing.
« Reply #5 on: November 21, 2008, 03:22:27 PM »
Thanks Dave and Jason for solving my problem.
I am running Vista. Guess I will just have to put up with it. It still kind of works just not very well.
Cheers,
Alex
« Reply #6 on: November 21, 2008, 04:48:17 PM »
lol! Then I wish you much luck and keep a rubber ball nearby to squeaze when you feel the urge to smash your monitor -  ;)
Offline ataxy
  •  31 31
« Reply #7 on: January 31, 2009, 04:31:05 PM »
weird i have no problem under vista
