Hello Guest it is October 21, 2026, 01:38:12 PM
Author Topic: Vista 64bit  (Read 28787 times)
Vista 64bit
« on: November 21, 2008, 04:42:41 AM »
I'm building myself a new computer with 4gb of ram.  The only way to use 4gb of ram I must install Vista 64.  Is it possible to use Mach3 with Vista 64.  I really don't want to have dual OS but I'd love to use Mach3 instead of getting another software.
Re: Vista 64bit
« Reply #1 on: November 21, 2008, 08:03:55 AM »
I don't believe Mach will run in 64bit Vista, but what other alternative software does?
Re: Vista 64bit
« Reply #2 on: November 21, 2008, 12:46:40 PM »
Are you sure that it won't work in WoW mode 32bit emulator?
Offline docltf
  •  354 354
Re: Vista 64bit
« Reply #3 on: November 22, 2008, 02:13:23 AM »
nope ,only 32 bit. i think the latest release of vista 32 supports more than  3 gig. you will have to check it out.
Re: Vista 64bit
« Reply #4 on: November 22, 2008, 02:31:23 AM »
I have Laptop Celeron 1200mhz with XP and 512mb of ram.  I heard there is a problem between laptop port and Mach3 so what is the problem?  Can I use Laptop safely?
Re: Vista 64bit
« Reply #5 on: November 22, 2008, 07:10:14 AM »
With a laptop, the only way to know for sure is to install Mach3 and try it.
Re: Vista 64bit
« Reply #6 on: February 19, 2009, 11:12:24 PM »
Is the status of mach and 16 bit going to change in the near or distant future
Offline scottybev
  •  23 23
  • A nice batch of archtops
Re: Vista 64bit
« Reply #7 on: March 03, 2009, 03:19:16 PM »
[u]WILL THIS SYSTEM WORK WITH MACH 3 OR DID I JUST LOOSE A GRAND????[/u]
Product
HP xw4600 Workstation with Energy Efficient Chassis
Operating system
Windows Vista® Business 32 w/downgrade to Windows XP Professional
Processor
Intel® Pentium® Dual-Core Processor E2180/2.00 GHz, 1MB L2, 800MHz FSB
Memory
2GB (2x1GB) DDR2-800 ECC
Video/Graphics
NVIDIA Quadro NVS 290 256MB PCIe
Hard drive
80GB SATA 3Gb/s NCQ 7200RPM
Optical Driver
HP 16X DVD+/-RW SuperMulti SATA
Startech PCI2s2p 2 port parallel PCI card
Much appreciated
Scotty
Offline TimGS
  •  108 108
Re: Vista 64bit
« Reply #8 on: July 27, 2009, 09:30:59 AM »
I've just built a Vista-64bit machine; I will attempt to use Mach3 in compatibility 32-bit compatibility mode.  Any tips/solutions will be appreciated.
Offline scottybev
  •  23 23
Re: Vista 64bit
« Reply #9 on: July 27, 2009, 07:26:17 PM »
WORKING LIKE A DREAM FOR ME, WITH NO ISSUES. JUST MAKE SURE ITS AN HP WORK STATION.
Much appreciated
Scotty
