Hello
Guest
it is
November 07, 2026, 07:04:13 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Feature Requests
Binary or BCD inputs and outputs.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Binary or BCD inputs and outputs. (Read 17212 times)
Buddy1
8
on:
November 14, 2008, 03:18:18 PM »
Can you increase the
inputs
and
outputs
by specifying some of the parallel port pins as Binary or BCD? How? 4 bits would be good.
Thanx
Buddy
Logged
ART
1,703
Tough as soggy paper.
Re: Binary or BCD inputs and outputs.
Reply #1 on:
November 14, 2008, 10:09:44 PM »
Hi:
There is an experimental mode for 5 bit multiplexing using the charge pump output as a multiplexor level sensor, if the charge pump is low, the input of 5 input bits on port1 is read as port 1, if the charge pump is low they are read as port 8. This allows for 10 input bits in total on port 1. This can only be done from a plugin by setting a system varible to that mode.
Art
Logged
Buddy1
8
Reply #2 on:
November 15, 2008, 09:36:35 AM »
Art
Thanx but you said low twice, i assume you meant high for port 8. Where can I get more detail on this?
Thanx
Buddy
Logged
ART
1,703
Reply #3 on:
November 15, 2008, 12:54:46 PM »
Hi:
sorry about that, I did indeed mean low.
Basically, ther eis a simple variable setting in the plugin system to turn on that mode. Are you now to the stage where you have a plugin?
Art
Logged
Buddy1
8
Reply #4 on:
November 15, 2008, 02:28:42 PM »
No...I have barely just read your manual, everything about Mach3 is new to me. I am sure I have a learning curve. I will have a 2 or 3 test systems going next week, stepper, servo(closed loop), and gecko w/dc motors.
Thanx
Buddy
Logged
ART
1,703
Reply #5 on:
November 15, 2008, 04:17:51 PM »
Hi Buddy:
I suggest you get everythign running with the typical 5 inputs.. its a large pearnign curve, adding a plugin to the curve probably isnt
productive at this point. When all else is dealt with you can start to worry about a plugin to swap the program to MUX mode.
Art
Logged
Buddy1
8
Reply #6 on:
November 15, 2008, 05:37:17 PM »
Thanx Art..will do. Hey...isn't cat fighting illegal in your state
Logged
ART
1,703
Reply #7 on:
November 15, 2008, 08:25:30 PM »
Depends on the cat..
Logged
Print
Pages:
1
Go Up
« previous
next »
