Hello Guest it is October 21, 2026, 09:45:22 AM
Author Topic: Using one Mach 3 Installation for multiple machines?  (Read 17776 times)
b0gh0s
« on: July 06, 2006, 04:32:17 PM »
Is there a way to setup Mach3 so that I can have two completely different machine profiles (all the settings for limits, stepper tuning, offsets, etc)?
I want to use it with a 4 axis mill and a 3 axis router bed, (not simultaneously).
IS there an easy way to do this?
Re: Using one Mach 3 Installation for multiple machines?
« Reply #1 on: July 06, 2006, 04:36:34 PM »
Just make seperate profiles for each machine then on starting Mach you can choose which one you want to use.
« Reply #2 on: July 07, 2006, 07:44:14 AM »
IF you copy the shortcut on the desktop and change the PMach3Mill the to P"whatever" you can set up two icons on the screen. It is under the properties of the icon...
www.newfangledsolutions.com
www.machsupport.com
