Hello Guest it is November 10, 2026, 02:33:50 AM
Author Topic: Control the Z axis when a program is running.  (Read 15280 times)
« on: November 07, 2008, 08:47:32 PM »
Hi, I am running a plasma/flame torch on my table and I was wondering if it is possible to run the z axis manually at the  same time mach 3 is running a program? Let me know if this would work.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Control the Z axis when a program is running.
« Reply #1 on: November 08, 2008, 03:40:00 AM »
What control are you wanting - height and on/off - or is the "target" undulating.
You can search the forum - this question has come up before - and, I think, been answered.
If you look in Config/Ports and Pins/Mill Options you will see a box refering to THC which I think is Torch Height Control. THis allows you (I think) to alter the height of the Z axis whilst "on the move".
I don't know for sure, becasue I don't use the feature.
« Reply #2 on: November 08, 2008, 04:21:44 PM »
I have searched the forum and can not find any good answers. I will check THC box and see if it lets me do that.
« Reply #3 on: November 09, 2008, 07:16:13 AM »
I beleive you might find what you need in this thread.
http://www.machsupport.com/forum/index.php/topic,6987.0.html
Best Regards
Fernando
« Reply #4 on: November 09, 2008, 07:29:40 PM »
hi, its easy to do.you are almost there.go to ports and pins/inputs/ thc up choose a unused input pin,thc down another input pin. what i use is a arcade joystick which has 2 micro switches.connect to your selected input pins. while i have thc arc control for plasma, i use the manual move for oxyactlyene cutting.
