Hello Guest it is November 22, 2026, 07:26:29 AM
Author Topic: Enabling backlash comp in 3.041  (Read 12847 times)
« on: November 07, 2008, 06:22:20 AM »
I have a tabletop mill setup and am looking for ways to enable backlash comp in 3.041.
I currently have .004 backlash in the X, .002 in the Y and .004 in the Z.  I'm using Kerkote 4tpi leadscrews.
System specs: Gecko 250 driver box and 300 oz in  steppers.  Mach setup; kernel speed 45000khz, CV mode on, distance mode to absolute, IJ mode to Inc.
Without backlash enabled the system runs smooth, if I enable backlash, it seems everything bogs down.
Any ideas?
TIA,
Michael
Re: Enabling backlash comp in 3.041
« Reply #1 on: November 07, 2008, 10:20:39 AM »
Hello Michael,
  You might tinker with the Shuttle settings. Has helped some in the past.
RC 8)
« Reply #2 on: November 07, 2008, 10:47:04 AM »
Thanks for the info.  Will try this tonight.
I should have added that I also have a xylotex based sytem with steppers and Mach 2.0.009 that has backlash enabled and runs smooth.
Will post my findings when I get time to try this.
