Hello Guest it is November 22, 2026, 07:01:39 AM
Author Topic: First chips; My PP woes?  (Read 18305 times)
« on: November 04, 2008, 11:56:19 AM »
So I finally made my first chips.
I'm having a problem that is possibly post processor related but I really don't know.
I'm running mastercam v8.2 and mach3. Default fanuc post processor. I've tried downloading two other post processors intended for mastercam and mach3 but they freeze up when I try to post. I would guess they're meant for a later version of mastercam?
The first thing the machine does is g0x0y0 and then plunge g1z-.08. It backs up and then continues on with what it is suppose to do. The initial plunge was not programmed in nor intended. It is suppose to start with pocketing two holes at a different location.  I've verified with mastercam and can't figure out what the problem is.
Any ideas?
Adam
Re: First chips; My PP woes?
« Reply #1 on: November 04, 2008, 12:18:56 PM »
Can you attach your code please.
« Reply #2 on: November 04, 2008, 12:31:37 PM »
Wasn't sure if you wanted it in it's entirety or not but here it is.
Code: [Select]
O0000
(PROGRAM NAME - SOFT JAWS - 1)
(DATE=DD-MM-YY - 24-10-08 TIME=HH:MM - 18:45)
N100G20
N102G0G17G40G49G80G90
/N104G91G28Z0.
/N106G28X0.Y0.
/N108G92X0.Y0.Z0.
(3/8 FLAT ENDMILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .375)
N110T1M6
N112G0G90X-1.2539Y-.3024A0.S1426M3
N114G43H1Z.25
N116Z.1
N118G1Z-.08F6.33
N120X-1.2461
N122G3X-1.1725Y-.225R.0775
N124X-1.2461Y-.1476R.0775
N126G1X-1.2539
N128G0Z.25
N130Y-.3024
N132Z.02
N134G1Z-.16
N136X-1.2461
N138G3X-1.1725Y-.225R.0775
N140X-1.2461Y-.1476R.0775
N142G1X-1.2539
N144G0Z.25
N146Y-.3024
N148Z-.06
N150G1Z-.24
N152X-1.2461
N154G3X-1.1725Y-.225R.0775
N156X-1.2461Y-.1476R.0775
N158G1X-1.2539
N160G0Z.25
N162Y-.3024
N164Z-.14
N166G1Z-.32
N168X-1.2461
N170G3X-1.1725Y-.225R.0775
N172X-1.2461Y-.1476R.0775
N174G1X-1.2539
N176G0Z.25
N178Y-.3024
N180Z-.22
N182G1Z-.34
N184X-1.2461
N186G3X-1.1725Y-.225R.0775
N188X-1.2461Y-.1476R.0775
N190G1X-1.2539
N192G0Z.25
N194X1.2461Y-.3024
N196Z.1
N198G1Z-.08
N200X1.2539
N202G3X1.3275Y-.225R.0775
N204X1.2539Y-.1476R.0775
N206G1X1.2461
N208G0Z.25
N210Y-.3024
N212Z.02
N214G1Z-.16
N216X1.2539
N218G3X1.3275Y-.225R.0775
N220X1.2539Y-.1476R.0775
N222G1X1.2461
N224G0Z.25
N226Y-.3024
N228Z-.06
N230G1Z-.24
N232X1.2539
N234G3X1.3275Y-.225R.0775
N236X1.2539Y-.1476R.0775
N238G1X1.2461
N240G0Z.25
N242Y-.3024
N244Z-.14
N246G1Z-.32
N248X1.2539
N250G3X1.3275Y-.225R.0775
N252X1.2539Y-.1476R.0775
N254G1X1.2461
N256G0Z.25
N258Y-.3024
N260Z-.22
N262G1Z-.34
N264X1.2539
N266G3X1.3275Y-.225R.0775
N268X1.2539Y-.1476R.0775
N270G1X1.2461
N272G0Z.25
N274X-1.1625Y-.225
N276Z.1
N278G1Z-.08
N280G3X-1.25Y-.1375R.0875
N282X-1.3375Y-.225R.0875
N284X-1.25Y-.3125R.0875
N286X-1.1625Y-.225R.0875
N288G1Z-.16
N290G3X-1.25Y-.1375R.0875
N292X-1.3375Y-.225R.0875
N294X-1.25Y-.3125R.0875
N296X-1.1625Y-.225R.0875
N298G1Z-.24
N300G3X-1.25Y-.1375R.0875
N302X-1.3375Y-.225R.0875
N304X-1.25Y-.3125R.0875
N306X-1.1625Y-.225R.0875
N308G1Z-.32
N310G3X-1.25Y-.1375R.0875
N312X-1.3375Y-.225R.0875
N314X-1.25Y-.3125R.0875
N316X-1.1625Y-.225R.0875
N318G1Z-.34
N320G3X-1.25Y-.1375R.0875
N322X-1.3375Y-.225R.0875
N324X-1.25Y-.3125R.0875
N326X-1.1625Y-.225R.0875
N328G0Z.25
N330X1.1625
N332Z.1
N334G1Z-.08
N336G3X1.25Y-.3125R.0875
N338X1.3375Y-.225R.0875
N340X1.25Y-.1375R.0875
N342X1.1625Y-.225R.0875
N344G1Z-.16
N346G3X1.25Y-.3125R.0875
N348X1.3375Y-.225R.0875
N350X1.25Y-.1375R.0875
N352X1.1625Y-.225R.0875
N354G1Z-.24
N356G3X1.25Y-.3125R.0875
N358X1.3375Y-.225R.0875
N360X1.25Y-.1375R.0875
N362X1.1625Y-.225R.0875
N364G1Z-.32
N366G3X1.25Y-.3125R.0875
N368X1.3375Y-.225R.0875
N370X1.25Y-.1375R.0875
N372X1.1625Y-.225R.0875
N374G1Z-.34
N376G3X1.25Y-.3125R.0875
N378X1.3375Y-.225R.0875
N380X1.25Y-.1375R.0875
N382X1.1625Y-.225R.0875
N384G0Z.25
N386X-1.25Z.1
N388G99G83Z-1.R.1Q.1F6.33
N390X1.25
N392G80
N394X-2.4125Y-.8749Z.25
N396Z.1
N398G1Z-.02
N400X2.225
N402G3X2.35Y-.7499R.125
N404X2.225Y-.6249R.125
N406G1X-2.225
N408G2X-2.35Y-.4999R.125
N410X-2.225Y-.375R.125
N412G1X2.225
N414G3X2.35Y-.25R.125
N416X2.225Y-.125R.125
N418G1X-2.225
N420G2X-2.35Y0.R.125
N422X-2.225Y.125R.125
N424G1X2.225
N426G3X2.35Y.25R.125
N428X2.225Y.375R.125
N430G1X-2.225
N432G2X-2.35Y.4999R.125
N434X-2.225Y.6249R.125
N436G1X2.225
N438G3X2.35Y.7499R.125
N440X2.225Y.8749R.125
N442G1X-2.4125
N444G0Z.25
N446X-2.Y1.0625
N448Z.1
N450G1Z-.0921
N452X2.
N454G2X2.1875Y.875R.1875
N456G1Y-.875
N458G2X2.Y-1.0625R.1875
N460G1X-2.
N462G2X-2.1875Y-.875R.1875
N464G1Y.875
N466G2X-2.Y1.0625R.1875
N468G1Z-.1843
N470X2.
N472G2X2.1875Y.875R.1875
N474G1Y-.875
N476G2X2.Y-1.0625R.1875
N478G1X-2.
N480G2X-2.1875Y-.875R.1875
N482G1Y.875
N484G2X-2.Y1.0625R.1875
N486G1Z-.2764
N488X2.
N490G2X2.1875Y.875R.1875
N492G1Y-.875
N494G2X2.Y-1.0625R.1875
N496G1X-2.
N498G2X-2.1875Y-.875R.1875
N500G1Y.875
N502G2X-2.Y1.0625R.1875
N504G1Z-.3686
N506X2.
N508G2X2.1875Y.875R.1875
N510G1Y-.875
N512G2X2.Y-1.0625R.1875
N514G1X-2.
N516G2X-2.1875Y-.875R.1875
N518G1Y.875
N520G2X-2.Y1.0625R.1875
N522G1Z-.4607
N524X2.
N526G2X2.1875Y.875R.1875
N528G1Y-.875
N530G2X2.Y-1.0625R.1875
N532G1X-2.
N534G2X-2.1875Y-.875R.1875
N536G1Y.875
N538G2X-2.Y1.0625R.1875
N540G1Z-.5529
N542X2.
N544G2X2.1875Y.875R.1875
N546G1Y-.875
N548G2X2.Y-1.0625R.1875
N550G1X-2.
N552G2X-2.1875Y-.875R.1875
N554G1Y.875
N556G2X-2.Y1.0625R.1875
N558G1Z-.645
N560X2.
N562G2X2.1875Y.875R.1875
N564G1Y-.875
N566G2X2.Y-1.0625R.1875
N568G1X-2.
N570G2X-2.1875Y-.875R.1875
N572G1Y.875
N574G2X-2.Y1.0625R.1875
N576G1Z-.665
N578X2.
N580G2X2.1875Y.875R.1875
N582G1Y-.875
N584G2X2.Y-1.0625R.1875
N586G1X-2.
N588G2X-2.1875Y-.875R.1875
N590G1Y.875
N592G2X-2.Y1.0625R.1875
N594G0Z.25
N596M5
N598G91G28Z0.
N600G28X0.Y0.A0.
N602M30
« Reply #3 on: November 04, 2008, 12:43:15 PM »
Have a look in your tool table and see if you have any offsets for tool 1.
 If not then can you tell me exactly which line the Z plunges.
« Reply #4 on: November 04, 2008, 03:10:35 PM »
N118 is the line where it plunges -.08 What's the N118 for?
I don't know what my tool table is. Is this something in mastercam or mach3?
« Reply #5 on: November 04, 2008, 03:22:21 PM »
The code is telling it to plunge by that amount so you need to look in your CAM or PostProcessor and see why it is doing that.
The N118 is simply a line number, some people like line numbers as it makes editing code easier as they can go to a line easier when its numbered. I prefer not to have them but everyone to their own. Again this should be an option you could ediit in your post processor.
« Reply #6 on: November 04, 2008, 03:28:17 PM »
Hmm,
I've looked at the fanuc post and have not idea what I would need to edit, though it does say that it is a generic post and should need editing.
I've also tried looking for other posts that people have been successful with but every time I try to post in mastercam, the machine hangs up and I get the hourglass indefinitely. I presume because the post is for a newer version of mastercam?
Adam
« Reply #7 on: November 04, 2008, 03:36:50 PM »
I dont use MasterCAM so cant really help but there is a chance it could even be in MasterCAM itself that you need to change a setting.
