Hello Guest it is November 22, 2026, 06:52:56 AM
Author Topic: circle centre V1 by German Bravo help  (Read 17202 times)
« on: November 04, 2008, 11:47:57 AM »
hi could some one let no how to use this wizard ,Touch point A,B,C,??????? i under stand i have to touch the edge of my part with edge finder but were is A B C , Then what?
Thanks Rob
vmax549
Re: circle centre V1 by German Bravo help
« Reply #1 on: November 04, 2008, 12:00:49 PM »
ABC can be anywhere inside of the circle you just need 3 points to calculate the center.
Basically you press start then move to touch off at the first point then press the 1st point button ,next move to the 2nd point,then the 3rd point. Then press go to center and mach should go to COC.
Hope that helps, (;-) TP
« Reply #2 on: November 04, 2008, 12:08:56 PM »
hi vmax549
Thanks that clears that up, but were do i type in the diameter of my edge finder?
thanks Rob
« Reply #3 on: November 04, 2008, 12:22:16 PM »
you dont need the dia of your edge finder as whether it was 0.1 or 1.0 it would be the same at each touch point. If you were finding the edge of a part or the corner of a part then that is when you would need the dia of the edgefinder.
vmax549
« Reply #4 on: November 04, 2008, 12:24:10 PM »
Hood has it correct, if only finding COC then as long as the offsett remains the same it will correctly go to COC.
« Reply #5 on: November 04, 2008, 12:33:09 PM »
HI thank all ' one day my brain will start working , just tyred it out works a charm
THANKS AGAIN FOR YOUR HELP
Rob
« Reply #6 on: November 04, 2008, 12:47:53 PM »
When you manage to get your brain working please post the How To, I will give it a go ;)
« Reply #7 on: November 04, 2008, 01:04:47 PM »
HA HA HA HA HA will do' it may take some time.
Rob
