Hello Guest it is October 25, 2026, 02:59:39 AM
Author Topic: C11 breakout board/trying to use the 110 AC Relay  (Read 11253 times)
« on: November 03, 2008, 11:55:49 PM »
Can someone tell me which pin to use or how to configure Mach to use the 110 AC Solid State Relay?  It says pin one on it.  When i configure mach to use pin 1 is turns on and off the pin 1 which is located with the step / direction pins.  I will like to use an high speed Dremel tool and control it on/off with the program.
  •  9,374 9,374
Re: C11 breakout board/trying to use the 110 AC Relay
« Reply #1 on: February 06, 2009, 04:41:01 AM »
Hi Dajavu,
The charge pump safety circuit for spindle control should be what you are looking for, here is the link:-
http://www.machsupport.com/docs/ChargePumpSafety.pdf
