Hello Guest it is October 21, 2026, 04:40:55 PM
Author Topic: Hiwin single axis robots  (Read 14341 times)
« on: November 03, 2008, 06:11:24 PM »
hello guys,
Has anyone ever worked with the single axis robots from HIwin?
Im wondering if they are stiff enough. Im planning on using them to make a 20ft x 12" x6" milling machine... to machine long steel parts...
wondering if they are stiff enough for the 12 and 6 inch axes, to machine steel, even if i have to take 1/16" or 1/32" passes.
Best regards
Fernando
Re: Hiwin single axis robots
« Reply #1 on: November 03, 2008, 06:56:34 PM »
Fenando,
 20' or 2'?
What load can you place on them?
« Reply #2 on: November 04, 2008, 05:05:40 AM »
Hello Rich,
20 feet
planning on using normal rails and rack and pinion on that axis.
The single axis robots would be used in the 12inch and 6 inch axes.
I see they can take quite a load,
Its just that for the size and configuration of the unit, is hard to beleive that they can take that much
here is the loading table:
Best Regards
Fernando
« Last Edit: November 04, 2008, 05:07:27 AM by fer_mayrl »
