Hello Guest it is September 22, 2026, 10:15:43 AM
Author Topic: homing or toolchange macro help needed  (Read 15326 times)
« on: November 01, 2008, 03:17:07 PM »
Hi Everyone,
I am trying to write a macro that will move to a home or tool change position for milling
it looks like this
Feed=GetDRO(18)
ofset=GetDRO(0)    - This must read which coordinate is active G54, g55, g56 etc.
code "g54"             - This must set G54 (Machine coordinates
Code "g00  Z0"      - This must move Z home (or tool change position)
code "g00 x0 y0"   - This must home X and Y
SetDRO(18,Feed)  - this must restore feedrate
setDRO(0,ofset)  - This must restore coordinate that was used before homing (this line seems to be the problem)
sadly this macro doesn't work
can anyone please help
Re: homing or toolchange macro help needed
« Reply #1 on: November 02, 2008, 05:43:13 AM »
There are a lot better at VB and G Code than me but give this a go and see if it does what you want. I am not sure if you actually need to set your feedrate  DRO as you have because they shouldnt really change anyway.
Feed=GetDRO(18)
 ofset=GetDRO(0)    'This must Read which coordinate is active G54, g55, g56 etc.
Code ("G53 G0  Z0")      'This must move Z home (Or tool change position)
While IsMoving
Sleep (10)
Wend
code ("g53 G0 x0 y0")   ' This must home X And Y
While IsMoving
Sleep (10)
Wend
Call SetDRO(18,Feed)  'this must restore feedrate
Call setDRO(0,ofset)  'This must restore coordinate that was used before homing (this Line seems To be the problem)
« Last Edit: November 02, 2008, 06:13:53 AM by Hood »
« Reply #2 on: November 02, 2008, 06:12:40 AM »
Just been messing with it, maybe this would be better but again I dont really know what I am doing so test with caution.
 Feed=GetDRO(18)
 ofset=GetDRO(46)    'This must Read which coordinate is active G54, g55, g56 etc.
Code ("G53 G0  Z0")      'Moves Z to Machine CoOrds Zero
While IsMoving
Sleep (10)
Wend
code ("g53 G0 x0 y0")   ' Moves X and Y to Machine CoOrds Zero
While IsMoving
sleep (10)
Wend
Call SetDRO(18,Feed)  'Sets feedrate DRO (Not sure this is really needed)
Code ("ofset") 'Sets back to previous offset
End
« Reply #3 on: November 02, 2008, 07:46:02 AM »
Welcome to my world -  :D
« Reply #4 on: November 02, 2008, 01:40:35 PM »
Thanks Hood, thats done the trick  ;D
