Hello Guest it is November 07, 2026, 10:44:38 AM
Author Topic: general newbie questions  (Read 31723 times)
Re: general newbie questions
« Reply #10 on: November 03, 2008, 10:02:46 AM »
  Does this mean what I think it says, that I can load a Jpeg or BMP into LazyCam, and either it or Mach3 will convert it to something that they can generate Gcode from?
No, not what you think. LazyCAM will create g-code from the image, but the g-code will be for a 3D carving of the image, not a trace of it.
« Reply #11 on: November 03, 2008, 07:59:13 PM »
OK, then how about this: if a CAD image contains Bezier curves, can LazyCam handle it, or does it work with arcs only?
« Reply #12 on: November 03, 2008, 08:35:24 PM »
I don't think so. But at some point, the bezier curves (or splines) need to be converted to arcs or line segments, because there are no g-codes for bezier curves.
