Hello Guest it is November 12, 2026, 05:10:15 AM
Author Topic: Dobutton(21)  (Read 8552 times)
Dobutton(21)
« on: October 31, 2008, 05:38:24 AM »
Hi there ,
    My name is olsson , I bought my license for the mach3 here in brazil , by "CNCBR" and I just start my application . I have one doubt  with my application I wrote one code for the button but that doesn't work , may be anyone can help me . You can see the code below.
Dobutton(21)
Activatesignal(7)
When I press the button once the mach reset , if I press again the charge pump signal is goes on but the output1 reaming off.
Re: Dobutton(21)
« Reply #1 on: October 31, 2008, 03:50:09 PM »
DoOEMButton(1021)
ActivateSignal(OUTPUT1)
NOTE: all your outputs are Killed if the Reset is active.......
