Hello
Guest
it is
October 20, 2026, 03:09:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
4th Axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 4th Axis (Read 18289 times)
biffo
11
4th Axis
on:
October 29, 2008, 08:08:26 AM »
Hi All
I joined the forum after completing the cnc conversion on my X3 when I converted it I made provision for a fourth axis which I have now installed Mach 3 sees it ok but when I used the gear cutting NFS wizard x and y do what they are supposed to do but A axis does not respond. Any Ideas?
Biffo
Logged
Chaoticone
5,624
Precision Chaos
Re: 4th Axis
Reply #1 on:
October 29, 2008, 08:32:12 AM »
Welcome, your free to post in other boards now.
Logged
If you could see the things I have in my head, you would be laughing too.
Graham Waterworth
2,785
Yorkshire Dales, England
Re: 4th Axis
Reply #2 on:
October 29, 2008, 11:38:46 AM »
Hi Biffo,
can you jog the A axis using the keyboard?
Graham
Logged
biffo
11
Re: 4th Axis
Reply #3 on:
October 29, 2008, 02:00:09 PM »
Hi
To be honest I have not tried using the keyboard to jog the A axis but have only ued the 4th axishe jogging flyout to jog it which works fine.
Biffo
Logged
Graham Waterworth
2,785
Re: 4th Axis
Reply #4 on:
October 29, 2008, 02:11:22 PM »
OK,
What happens if you type this code into MDI
G00 G90 A90.
put a sample of your code here for me to look at.
Graham
Logged
biffo
11
Re: 4th Axis
Reply #5 on:
October 30, 2008, 08:24:25 AM »
Hi
On running you code the A axis moves for about half a complete turn of the table. Here is the code I am trying to run
G00 G64 A0.0
Y-30.1 X0
(This program has No Z moves!)
M98 (Index.tap) Q20
M5 M9
M30
Biffo
Logged
Graham Waterworth
2,785
Re: 4th Axis
Reply #6 on:
October 30, 2008, 02:11:02 PM »
OK, I would have expected it to just move 1/4 turn.
The code you have shown may need a tweak
G00 G90 A0.0
Y-30.1 X0
M98 (Index.tap) L20
M5 M9
M30
Try it like this and let me know how it has changed
Graham
Logged
biffo
11
Re: 4th Axis
Reply #7 on:
October 31, 2008, 04:46:40 AM »
Hi
We seem to be getting there your code worked fine with the rotary table moving the correct amount so
I tried running the NFS wizard to cut a 30mm dia wheel blank with 20 teeth it spends 4 minutes cutting the first tooth the at the end rotates 18 deg and starts again on the next tooth I would have expected it to cut one tooth then rotate to the next one but I could be wrong.
cheers
Biffo
Logged
Graham Waterworth
2,785
Re: 4th Axis
Reply #8 on:
October 31, 2008, 06:54:42 AM »
Good, thing are working.
I would post your NFS problems in the NFS area an may be Ron Ginger will answer you, Ron maintains the wizards so he should know the ins and outs.
Graham
Logged
Print
Pages:
1
Go Up
« previous
next »
