Hello Guest it is September 12, 2026, 05:00:17 AM
Author Topic: Tool Offsets  (Read 12662 times)
FastCote
Tool Offsets
« on: July 01, 2006, 03:34:28 PM »
Most likely I am just confused, but i thought LC was able to offset the cutting path by half the tool diameter. (inside or outside) I can not seem to get this to work. the only tool setting i see related to the path chain is a tool number option. I don't see a diameter setting anywhere. i assumed this tool number was a reference to the M3 tool database. Changing the tool NUMBER does not seem to do anything. I think i have configured the correct tool size in M3 but to no avail.
Any guidance??
FastCote
Re: Tool Offsets
« Reply #1 on: July 01, 2006, 08:30:53 PM »
There is a way but it is using the Cutter comp in Mach3.... Check the G41/42 Cutter Comp mode and you should have it working
www.newfangledsolutions.com
www.machsupport.com
Re: Tool Offsets
« Reply #2 on: January 27, 2007, 07:59:19 AM »
Where do I find that option?  I have Mach3 Version R2.0.021.  I'm Using LazyCAM and telling it to cut on the left and right sides of the lines, but in the gcode it produces I only see a G40, never a G41 or G42.
Q
Re: Tool Offsets
« Reply #3 on: January 28, 2007, 10:34:18 PM »
Under File you should see posting options. In there you can check (Use G41/42)
hope that helps
Brian
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Tool Offsets
« Reply #4 on: January 29, 2007, 11:15:55 PM »
Hi, FastCote
In Mach3 set tool settings in tool table, Offsets screen, bottom right.
Hope this Helps, Chip
