Hello Guest it is October 24, 2026, 03:10:03 PM
Author Topic: cripled code  (Read 30192 times)
cripled code
« on: October 26, 2008, 07:38:07 AM »
 :o
When I make a code using the wizard for a circle etc.
it seems to be allright.
But in the middle of the code every time the last sentence is given and the process is stopped.
Any idea what this can e?
(any electrical thing?)
The original code before downloading seems to be ok.
Kind regards
Re: cripled code
« Reply #1 on: October 28, 2008, 08:15:54 PM »
Im sorry, but I do not understand your problem.
If you mean the NFS set of wizards, they do require a license. When you run the wizard without a license it works, and will pre-view the code, but when you return to Mach the code is replaced by a message, I think it says "no license found'
Is this the problme yu see?
Re: cripled code
« Reply #2 on: November 01, 2008, 06:52:00 PM »
No Ron I already bought the lic file a year ago.
The problem is that somtimes, when the generated code becomes too long the code changes in an endless lopp or to say it in another way is given the same code sentence again and again so that the process stops.
Perhaps it is electric??
Kind regards,
Andre
