Hello Guest it is November 23, 2026, 01:09:43 AM
Author Topic: Flame Cutting  (Read 12760 times)
Flame Cutting
« on: October 25, 2008, 02:38:07 AM »
Hi All,
Planning to assemble a CNC Flame cutting.
Does anyone know of a Torch height control for Flame cutting,
And how is the initial ignition done?
Antony.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Flame Cutting
« Reply #1 on: October 26, 2008, 02:18:25 AM »
The flame cutting I have seen at my local profiler is a relatively simple job. His machine worked on paper diagrams, which the machine then followed. He has probably stepped up to CNC since the last time I was there.
Mach 3 can control the X and Y axis quite easily, whilst the Z axis will take care of the torch height.
There are plenty of otputs for ignition either an M3 (which is ispindle motor "on" - but you can use as a torch control) or you can adapt one of the other outputs quite simply.
Re: Flame Cutting
« Reply #2 on: October 26, 2008, 03:02:10 AM »
Hi Jim,
I am looking for a kind of THC application as in a Plasma.
The M3 function is clear to me.
Is there any mechanism for the ignition and where to source the solenoid valves.
