Hello
Guest
it is
November 22, 2026, 03:37:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Synchronising Motors
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Synchronising Motors (Read 28743 times)
bigbigjimbo
64
on:
October 23, 2008, 01:07:34 PM »
Hi
I want to have two motors driving on the one axis, I understand these have to be synchronised and this is done in Mach. can someone please step me through it or give me a link to how its done.
Jimbo
Logged
Chaoticone
5,624
Precision Chaos
Re: Synchronising Motors
Reply #1 on:
October 23, 2008, 09:06:06 PM »
Jimbo, give us more detail please. Is this a gantry router with motors on each side of the gantry?
Logged
If you could see the things I have in my head, you would be laughing too.
bigbigjimbo
64
Reply #2 on:
October 23, 2008, 09:37:17 PM »
Bret,
Yes it is a Gantry It is going to be Joe's 4x4 Hybrid I am at the planning stage but I have never dealt with the twin motors before.
Jim
Logged
bigbigjimbo
64
Reply #3 on:
October 23, 2008, 09:38:07 PM »
Sorry yes the motors are at each side of the gantry.
Logged
Chaoticone
5,624
Precision Chaos
Reply #4 on:
October 23, 2008, 09:47:42 PM »
Jimbo, It should be as simple as slaveing the motors for the axis. For example, X master and a slave. This is done in config, ports and pins.
Logged
bigbigjimbo
64
Reply #5 on:
October 23, 2008, 10:11:59 PM »
Brett,
OK so do you use two controllers?
And lets say the axis is Y then you go to slave and under the Y axis you call the other motor say X and thats it.
(Sorry I am describing the slave thing from memory. ) and then whatever speed etc. settings you have set up for the Y is transferred to the X at the same time ?
Have i got it right.
Jim
Logged
scudzuki
51
Reply #6 on:
October 23, 2008, 10:30:21 PM »
You would slave the a, b, or c axis to the x axis. The slave axis motor would need its own driver. And yes, provided you have the motor tuning correct (most likely you would have identical motors, drivers, and tuning on the x and slave axis).
Joe
Logged
bigbigjimbo
64
Reply #7 on:
October 24, 2008, 12:16:29 AM »
Sounds simple enough, the only confusing pare here is knowing what axis to nominate to the X Axis. Like how do you know what to use as in A,B, or C axis.
This is probibly simpler that I think, i just cant get to grips with the Slave axis. with normal axis it is easy as you set up the tuning etc to the axis and the config to the axis and its easy to know what is what.
Jim
Logged
Carnoustie, Scotland
Reply #8 on:
October 24, 2008, 01:58:35 AM »
You can choose whichever axis you want from A, B anc C to slave with X, Y or Z. Obviously you cant slave an axis more than once but any combination of X,Y,Z and A,B,C will be fine
Logged
bigbigjimbo
64
Reply #9 on:
October 24, 2008, 02:04:20 AM »
I think I am not explaining this correctly, I know how to identify my XY and Z Axis and set them up, you say I can use A,B and C to slave with A,Y And Z. Lets say its the Y axis and I select A to slave with it. Now how do I set up A in config so that the motor knows what direction to turn etc. I have not seen a config for the A axis in mach. mind you I am working from memory just now at work but if I know where the set up for A is It should clarify all.
Jim
Logged
Print
Pages:
1
2
Go Up
« previous
next »
