Hello Guest it is September 05, 2026, 02:23:07 PM
Author Topic: NFS Wizard ?  (Read 26155 times)
NFS Wizard ?
« on: December 16, 2005, 11:37:29 PM »
I just downloaded the latest Mach and the Conversatinal wizard will not make G-code for any of the opperations?  When I click on "preview" it goes to a blank preview screen.  When I click "post code" it goes to the first page of the wizard were you select the material.  And no code posted to Mach.  It worked with the last Mach.  I'm prob. doing some thing wrong  ???  What should I start looking for?  The rest of the mach wizards work ok.  It is only the NFS ones that don't work.
Dennis
Re: NFS Wizard ?
« Reply #1 on: December 17, 2005, 10:08:18 AM »
Do you get any Gcode when you get back into Mach3?
I will load up the latest version and test as well.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: NFS Wizard ?
« Reply #2 on: December 17, 2005, 11:00:24 AM »
It is working here.... Are you getting a an Error on the Error line in mach3?  What wizard are you using?
Thank you
Brian
www.machsupport.com
Vmax
Re: NFS Wizard ?
« Reply #3 on: December 17, 2005, 11:05:05 AM »
Brian does he have a NFS license file present on his system?
Re: NFS Wizard ?
« Reply #4 on: December 17, 2005, 11:07:45 AM »
The preview should show the tool path with out a  license. But that is a good point!
Thank you
Brian
www.machsupport.com
Re: NFS Wizard ?
« Reply #5 on: December 17, 2005, 02:45:04 PM »
I got the license and I didn't move it from were it was before.   I get no gcode and no error in Mach or in the wizard.   I'm thinking maybe it is the computer or some software runing that is messing with it.  If it works on your computer Brian then should work here also.  I'm gana try the computer that is controlling the mill to see if it runs normal there.
Thanks for your time.  The panel wizard looks very nice!!
Re: NFS Wizard ?
« Reply #6 on: December 17, 2005, 03:27:02 PM »
Dennis,
If I can do anything to help I am here... well I am out tonight but after that I am...
Thank you
Brian
www.machsupport.com
Re: NFS Wizard ?
« Reply #7 on: December 17, 2005, 04:14:54 PM »
When I got home in the evening today I started working normal?   Computers ::)
Sorry to worry you!
