Hello Guest it is November 01, 2026, 11:29:13 AM
Author Topic: New problem after G80  (Read 13175 times)
Offline Psad
  •  82 82
« on: June 28, 2006, 03:58:44 PM »
Attached is the DXF and Tap file i've been working on today.
converted holes to dirll.  Program gets lost.  Line N100 should have a G1 after the G80 cancels the canned cycle.  I've had this happen onseveral files with 2.54 whe i change to drill.
Fantastic work on the program.  Getting much better with each release.
Now silly questions
??? is there a zoom  or pan in LZ.
 When i select a tool does LZ take in to account the cutter radius automatically or do i have to add  G40 to G42 in my code.
Re: New problem after G80
« Reply #1 on: June 28, 2006, 05:09:36 PM »
I will put in a fix for the G01's after the G80's :)
To pan and zoom press the shift or Crtl button & hold down the left mouse button When you move the mouse the view will change...
To use cutter comp you need to have G41/G42 turned on under the posting options.. The leadin size must be greater or = to the tool Dia. The tool Dia also needs to be in the tool table in Mach3...
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Psad
  •  82 82
« Reply #2 on: June 28, 2006, 05:45:39 PM »
what do yo mean "posting Options" where is that ???
Offline Psad
  •  82 82
« Reply #3 on: June 28, 2006, 05:47:13 PM »
never mind - I found it
