Hello Guest it is November 23, 2026, 01:09:46 AM
Author Topic: still getting softlimits warning  (Read 26340 times)
Re: still getting softlimits warning
« Reply #10 on: October 22, 2008, 05:41:02 AM »
I included fixtures.dat and a screenshot of the offsets table. Thanks in advance. How do you ever get any real work done when you spend so much time helping out here?
Joe
« Reply #11 on: October 22, 2008, 07:29:47 AM »
Well thats probably the reason I never have any money ;D
Ok get the softlimits on Y when I use your profile/code.offsets. What I did notice though is it is only giving me the warning on the first run, after that it will not warn. What I then did was open Mach, Ref All and then typed G56 into the MDI line and then when I started the code I never got the SoftLimits warning. I dont use offsets much so have never come across this before but maybe the MDI before the offset is a clue to why its happening. Give that a go and let me know if you get the same.
« Reply #12 on: October 22, 2008, 04:48:18 PM »
So it's not just me...
Maybe if I include the G56 and the linear move in the same line...
Usually G54 is active (work offset 1). I used G56 because I had another offset saved in G54. I likely won't use offsets other than 1 often so I can try the routine using G54 and see if I get the same results.
Joe
