Hello Guest it is October 20, 2026, 06:43:49 PM
Author Topic: Slaving axis with different steps? & change Z while runing?  (Read 11579 times)
« on: October 15, 2008, 09:12:01 PM »
If X and A are slaved can I have different steps/per for A than X? or they have to be the same number? or is the steps number ignored in the A setting under motor tuning?
Is there a way to adjust the Z hight with a MPG or keys while the machine is running code?  This is a grinding application so as the tool wears I want to manually lower it as needed.
Re: Slaving axis with different steps? & change Z while runing?
« Reply #1 on: October 16, 2008, 08:11:31 AM »
All settings must be the same to be slaved.
There was a thread yesterday about raising and lowering the Z while running. It involves using the Torch Height Control and creating 2 buttons.
