Hello
Guest
it is
November 23, 2026, 02:11:46 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How to set the modbus output signal??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to set the modbus output signal?? (Read 17914 times)
Edison
25
on:
October 14, 2008, 11:14:58 AM »
Hi,all:
In the mach3 the modbus the input signal is set the port is 0 ,
but the output signal is mapping what??
Thanks for help!!
Edison
Logged
Edison
Carnoustie, Scotland
Re: How to set the modbus output signal??
Reply #1 on:
October 14, 2008, 07:20:15 PM »
What are you trying to do? is it a PLC? Are you wanting to set an output from a macro or a button or?
Logged
Edison
25
Reply #2 on:
October 15, 2008, 06:41:10 AM »
Hi£¬Hood£º
Now£¬I design a board like ModIO, the input signal is test ok, but I cann't understand the output signal setup.
I want set the output like the input and can from a macro.
Thanks!!
Edison
Logged
Edison
Reply #3 on:
October 15, 2008, 07:15:05 AM »
Well for me with the PLC it is as simple as
Call SetModOutPut (19,1)
That would turn on output 19
Logged
Edison
25
Reply #4 on:
October 15, 2008, 07:24:26 AM »
Hi£¬Hood:
That's ok,thanks!!
And how to output the word??
Thanks!!
Edison
Logged
Edison
Reply #5 on:
October 15, 2008, 07:50:12 AM »
heres a screenshot of the settings I have for the PLC.
Logged
Edison
25
Reply #6 on:
October 15, 2008, 08:30:45 AM »
Hi,Hood:
Your ModBusSettings send what to the PLC??
If I want to send 0x0fd to the plc, ....?
Thank
Edison
Logged
Edison
Reply #7 on:
October 15, 2008, 04:41:12 PM »
I have no idea about what is sent, the registers in the PLC start at 2048 for inputs (PLC Inputs, Mach Outputs) and thats what I have set up in the above screenset.
Logged
Print
Pages:
1
Go Up
« previous
next »
