Hello Guest it is November 22, 2026, 11:19:39 PM
Author Topic: which Breakout Board  (Read 33912 times)
Re: which Breakout Board
« Reply #10 on: June 25, 2006, 09:03:28 AM »
 Brian, backlash is not checked as enabled.
« Reply #11 on: June 26, 2006, 12:16:56 AM »
Just a shot in the dark here but this almost sounds like a bad motor wire connection.  Might be worth looking at all your solder joints?
HTH,
Sid
« Reply #12 on: June 26, 2006, 01:43:39 AM »
Hi Sid
Both X and Y have the same problems, but I'll check all connections.
« Reply #13 on: June 26, 2006, 07:18:14 AM »
This probably the most accurate fault description up to date:
All accesses don't work properly at low speed, all of them.
At high speed steppers working fine, the slower the speed the worth problem. All moves - jogging, G00, and all cutting moves go messy at low speed.
I disconnected steppers from shafts, so it can't be mechanical.
« Reply #14 on: June 26, 2006, 09:50:15 AM »
I think we are seeing not so good drives :(
www.newfangledsolutions.com
www.machsupport.com
« Reply #15 on: June 26, 2006, 10:00:19 AM »
I'll order Gecko 201, hopefully it will sort it out, thanks for helping
