Hello Guest it is October 21, 2026, 07:28:38 AM
Author Topic: USB "Pendants"  (Read 32989 times)
USB "Pendants"
« on: October 12, 2008, 12:38:59 PM »
Has anyone used one of these:
http://www.contourdesign.com/shuttlepro/
http://www.contourdesign.com/shuttlepro/shuttlexpress.htm
as a pendant for Mach?  Seems to me it would work nicely, and the configuration software appears to be very flexible, especially in allowing a single button to cycle through a list of operations so, for example, one button could be used to cycle through a list of jog step sizes or rates.  Seems to me the jog/shuttle wheels would also make a pretty nice way of jogging, albeit on only one axis at a time.
Re: USB "Pendants"
« Reply #1 on: October 12, 2008, 12:57:49 PM »
Hi Ray,
There's already a plugin for this and I use one and love it. You're not supposed to load the Contour software though as it somehow messes with the Mach 3 plugin. This is available for download in the Mach 3 plugin downloads area in the menus at the top of the page.
You can see mine here:
http://www.machsupport.com/forum/index.php/topic,7020.0.html
EDIT: also wanted to add that I've drilled and tapped the center aluminum wheel to accept a brass swivel handle so that it feels like an MPG.  :)
« Last Edit: October 12, 2008, 01:02:02 PM by budman68 »
Re: USB "Pendants"
« Reply #2 on: October 12, 2008, 01:36:48 PM »
Dave,
    Cool!  How long is the cord?
Re: USB "Pendants"
« Reply #3 on: October 12, 2008, 01:42:49 PM »
Ummm...lol, I'll have to get back to you on that - I do know you can use an extension on these with no issues but I'll get back to you shortly-
Re: USB "Pendants"
« Reply #4 on: October 12, 2008, 01:59:53 PM »
That would be 6' long, my friend-  :)
Re: USB "Pendants"
« Reply #5 on: October 12, 2008, 02:07:12 PM »
Dave,
    Thanks!
Offline Vogavt
  •  260 260
Re: USB "Pendants"
« Reply #6 on: October 12, 2008, 03:00:32 PM »
Look at the Fang Game Pad. I absolutely love mine!
http://www.ideazon.com/us/products/fanggamepad.asp
http://www.sureneeds.com/fang.html  $26.99
Re: USB "Pendants"
« Reply #7 on: October 12, 2008, 04:27:43 PM »
Were you able to interface it the way you wanted using only the utilities than came with it, or Mach macros, or both?
Offline Vogavt
  •  260 260
Re: USB "Pendants"
« Reply #8 on: October 13, 2008, 08:43:47 PM »
This thing in very configurable. You can setup any of the buttons to any keystroke you want. It will also handle combinations of keystrokes.  I've not played with the macros in Mach but if you can call a keystroke (or a combination) to invoke a macro, then this will handle it.
The utility that comes with it allows you to print out the modified configuration for whatever software you're using. It's also smart enough to know you're running Mach and to set itself up accordingly once you've launch Mach.
Amazing really.  Not sure why no one's pointed this one out before for use as a pendant.  Sometimes we humans take the hard approach, but not with this item. It's really easy to setup.
I've had mine for a while now and have never had any issues with it.
Includes an ample six foot cord.
Re: USB "Pendants"
« Reply #9 on: October 13, 2008, 09:16:19 PM »
Vogvat, I have something similar. The drawback with it is that windows sees it as a keyboard. I dropped it after I figured that out because i would still need my standard keyboard to edit code and enter values. With some imagination you may be able to get all the functionality you need out of it. Let us know how it goes if you persue it.
